VATS Key Stuck
Old Sep 28, 2024 | 03:54 PM
nkreitz's Avatar
nkreitz
Default VATS Key Stuck
Last weekend, my key cylinder locked up on me in the "on" position. I could push it forward to "crank" position, but could not twist to off. I wiggled it for 30 minutes or so and ultimately gave up. Bought a new key cylinder and used steering wheel puller loaner tool to get the job done today. As pictured, I have the old cylinder still wired in to the VATS so I can fire the car with the new "dummy key". Obviously I need to get a new VATS key cut to match the new dummy key. I know how to ohm the VATS to order a new one, but I still cannot get it out to do that!
Any tricks on how to get the key out? Is there a way I can take apart the cylinder? Would a locksmith be able to do this?
Old Sep 28, 2024 | 04:05 PM
WVZR-1's Avatar
WVZR-1
Unplug the connector at the bottom of the column and use the terminals on the harness going down the column and a meter to determine the VATS. Not knowing the year you could also do this, take your registration to a dealer and ask that they do a key code request from GM. Generally the VATS resistance will accompany that request. Most dealers charge for that service.
*** If you've considered bypassing it now would be the time!
Old Sep 28, 2024 | 04:28 PM
IHBD's Avatar
IHBD
Pro Mechanic
You don't have to get the key out. Measure across the two white wires.
Old Sep 28, 2024 | 08:36 PM
WVZR-1's Avatar
WVZR-1
Changed your mind?
Old Sep 29, 2024 | 08:42 AM
nkreitz's Avatar
nkreitz
Duh. Embarrassed I didn't even think of that. Thanks guys.
To VATS Key Stuck
