Blend door..?
Old Oct 24, 2024 | 12:40 PM
Polo Vert's Avatar
Polo Vert
Default Blend door..?
So I'm sorting through my new to me 93. Fixed quite a few things but still some to go. I pulled and fixed my C68 HVAC control module and it seems to work properly but I don't get any heat until I run it all the way up to 90*. Is this the notorious blend door issue?
Old Oct 24, 2024 | 02:41 PM
Rush91's Avatar
Rush91
Try and maybe disconnect the battery for about a minute, it may reset.......Also were the plugs and contacts good?
I thought the blend door issue is the noise it makes when you switch modes. I could be wrong on that........My ZR-1 has always has had a loud blend door, like it's slapping on something.
Old Oct 24, 2024 | 04:13 PM
Polo Vert's Avatar
Polo Vert
I'm just guessing. The air diverts between floor/dash/defroster like it's supposed to. It doesn't seen to be modulationg air temperature properly.
To Blend door..?
