1990 Spare tire?
Old Oct 24, 2024 | 07:06 PM
Handsoap's Avatar
Handsoap
Default 1990 Spare tire?
I've had my 1990 for about 4 months now and I realized that I should check up on my spare in the back to see if it's in good order. It was quite dirty, but everything was as it should be thankfully.
However, I'm not sure how much I trust a 34 going on 35 year old tire as my back-up. Any ideas where to get a new spare? couldn't I take it to a tire shop and have them replace the rubber with new rubber?
Old Oct 24, 2024 | 07:24 PM
Whaleman's Avatar
Whaleman
I don't know your size. My 96 uses a size you can buy at tire rack. Tire shops will not have it. Dan
Old Oct 24, 2024 | 09:59 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
See if this helps ...
https://www.corvetteforum.com/forums...-corvette.html
Old Oct 24, 2024 | 10:51 PM
IHBD's Avatar
IHBD
Pro Mechanic
A 90 is probably a T155/70-17. I bought a Continental in this size for my 92 early this summer in anticipation of an 8,500 mile 14 day trip. My tire guy had to order it in, but it was in local warehouse stock, I had it the next afternoon. $150. I didn't worry about having to run a couple thousand miles on the 32 year old spare if I had a problem with a road tire.
I always get a kick out of the "I carry a plug kit and a pump." comments. This is probably viable if you come out of your motel room in the morning to a flat. But if it looses air while running highway speeds, by the time you notice there's a handling problem and get to safety to inspect it, the sidewalls are probably going to be pretty messed up from running with low/no pressure. A "plug kit" isn't going to fix the sidewall damage. If you're trying to keep to an itinerary, you're going to need a serviceable spare.
Old Oct 25, 2024 | 01:49 AM
Goldcylon's Avatar
Goldcylon
I took mine to Discount tire and they special ordered me a replacement spare. Remember the rule 50/50 that's 50 miles and no more 50mph. Just enough to limp home or limp to a garage. As others stated it won't be in stock. GC
Old Oct 25, 2024 | 07:32 AM
Whaleman's Avatar
Whaleman
That makes sense as Discount tire and Tire rack are both owned by the same company and I know tire rack has it. I bought my Continental on Ebay. It was only 6 months old. That was maybe 4 years ago. Dan
Old Nov 2, 2024 | 07:08 PM
dburgjohn's Avatar
dburgjohn
it is not worth the risk to run an old tire. ghlkal shared a link, my response is first on that link. tirerack.com can fix you up with a spare and peace of mind
To 1990 Spare tire?
