Blend door arm
Old Nov 2, 2024 | 06:51 PM
Shefler's Avatar
Shefler
Default Blend door arm
Can you access the arm that goes from the blend door to the actuator from above the dash or do you HAVE to come from underneath by the ECM? The door can be moved by hand when you access it through the blower motor resistor opening so I'm guessing the arm became disconnected from door.
Old Dec 3, 2024 | 06:37 PM
Shefler's Avatar
Shefler
Come on...someone must have tried this. Or at least thought about trying it.
