Coolant spewing but not overheating
Old Nov 13, 2024 | 04:35 PM
Boztek Enterprises's Avatar
Boztek Enterprises
Default Coolant spewing but not overheating
Good Afternoon all. I have a 92 LT1 6spd. Here lately, once the car gets up to temp (200-205) and has been there for 10 minutes of driving, it has started spraying coolant all under the hood. I "think" it's coming from the thermostat housing. It only does it while driving, not while it's sitting and it is NOT OVERHEATING. Temp never gets over 205 and it does it with the A/C on or off. It is also intermittent. Basically, if I drive it to work, 12 miles of residential one way, it does it as I pull up to my office or to my house in the afternoon, but not every time. 49k original miles, bone stock and all original. I'm thinking thermostat went out so I'm replacing that, but I didn't know if anyone else had any insight. This car has never given me a day's problem in the 12 years I've owned it.
Can anyone help me out here?
Old Nov 13, 2024 | 05:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
are you over filling it
Old Nov 13, 2024 | 05:07 PM
Boztek Enterprises
Nope. Everything shows to be at correct level, no air in system according to the bleeder valve on the thermostat housing.
Old Nov 13, 2024 | 05:33 PM
Krusty84's Avatar
Krusty84
Bad rad cap? Hole in a hose somewhere? If the system can't build pressure, then it will boil over near the boiling point.
Old Nov 13, 2024 | 05:57 PM
beermanpete's Avatar
beermanpete
You need to watch it leaking to see where the leak is. When the engine is cold, open the hood, start it and wait until it starts leaking. It will likely start slowly and get worse as the pressure in the cooling system rises. Be careful to not get burned.
Old Nov 13, 2024 | 06:34 PM
ex-x-fire's Avatar
ex-x-fire
I bet that lower disc on the t stat fell off.
Old Nov 15, 2024 | 06:17 PM
Techun's Avatar
Techun
Cheap and easy try, get a new rad cap
Old Nov 17, 2024 | 10:58 AM
Whaleman's Avatar
Whaleman
You need to first see where it is "spraying" from. I would borrow a cooling system pressure tester from a box store and see just where it is leaking. That will tell you where the problem is. Dan
To Coolant spewing but not overheating
