Gear selection
Old Nov 28, 2024 | 03:28 PM
Beovision5's Avatar
Beovision5
4th Gear
Default Gear selection
Should I select overdrive or drive on the shift indicator on my C4 ?????
Old Nov 28, 2024 | 03:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Your post is in the C7 section, probably get better responses in the C4 section...
Old Nov 28, 2024 | 05:28 PM
Beast's Avatar
Beast
Use overdrive. If you want to play a little bit and shift through the gears, it doesn’t hurt it. At HPDE, I basically only use 2nd and 3rd, never go into OD. 3,000 track miles, 85,000 miles on the car and the trans is fine.
Old Nov 29, 2024 | 03:28 AM
Merged two threads together -
Old Nov 29, 2024 | 01:27 PM
b_willmon_'s Avatar
b_willmon_
I've never actually tried shifting through the gears. The leather boot is a bit shrunken from the years and it won't let the lever stretch enough to go into 1 so I've never tried, but when I'm on a backroad or going up the mountain I use the lower D to turn OD off. I leave it on in town.
To Gear selection
