Ignition Control Module
Old Jan 3, 2025 | 10:34 AM
C4 Steck's Avatar
C4 Steck
Default Ignition Control Module
Just wondering if there are any particular ICM’s I should be looking for. So far I found that Advance carries a GM Genuine Parts ICM and a GM store I found online carries an AC Delco Gold unit. Looking to stay away from the regular parts store brands like car quest and duralast. I figured the ones I mentioned would be best choice although probably all now manufactured in China. If anyone has a new in box OEM one feel free to reach out. Thanks.
Old Jan 3, 2025 | 11:02 AM
dburgjohn's Avatar
dburgjohn
regardless of who you choose don't forget the thermal paste between the parts. Very important to avoid heat failure.
Old Jan 3, 2025 | 07:25 PM
ULTM8Z's Avatar
ULTM8Z
Get the genuine GM one. Long story, but aftermarket ignition modules can alter spark timing. There's a table in the EPRPOM that deals with this and it's tuned to the OEM module.
Old Jan 3, 2025 | 08:47 PM
NickPSI's Avatar
NickPSI
I have found that buying all of the aftermarket inventory auto zone has also can get you back up and running.
Old Jan 4, 2025 | 07:28 AM
ex-x-fire's Avatar
ex-x-fire
Get the part # off of your module and look for an nos on ebay. Good sellers will have them listed that way.
Old Jan 4, 2025 | 10:02 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I can bet you any money that Standard Motor products make that part for all labels
Old Jan 6, 2025 | 12:41 PM
Rogue One's Avatar
Rogue One
I recently replaced my ICM as part of preventative maintenance. If the ICM fails it can leave you stranded, and I didn't want to take that chance. I know that many say to use dielectric grease, but I recommend using heat sink compound. Dielectric grease is used to insulate electrical circuits. Heat sink compound, as the name implies, conducts heat away from the coil drivers in the ignition module. I was trying to remember why and then saw this in another post.
Old Jan 6, 2025 | 03:55 PM
ULTM8Z's Avatar
ULTM8Z
Yep, which is why I carry a spare with me in the trunk. Also, yes, use heat sink compound.
I've had really good luck with this...
https://www.ebay.com/itm/40269844510...3ABFBMoLuz1odl
Old Jan 13, 2025 | 04:37 AM
C4 Steck's Avatar
C4 Steck
Thanks guys. Appreciate all the info
To Ignition Control Module
