I just saw this product on Mecum auction. It looks like a great product to use on our brake and gas lines to help prevent rust.Does anyone have experience using this?
Hawkeye56
I did not know about this and I will defiantly be getting some. It looks like it could help. Even if it worked half as good as they say it would be a good idea. Thank You, Dan
I agree 100% with you. Any protection we can add to 30 year old raw steel lines is a plus.
Thank you
Hawkeye56
I was thinking about protecting the outside of the steel lines.
I would suggest giving Boeshield a try. It is a waxy, yellowish coating that leaves a finish similar to "cosmolene" seen on European cars prior to shipping them across oceans. Packaged in an aerosol can. I've used it on raw metal adjustment screws on the motor mounts and other applications on the yachts. It would be perfect for the fuel and brake lines running under the car on a C4. Park brake mechanisms too. Developed by the Boeing company. Good stuff.
If your break system is sealed how can moisture get in? Keep your fuel tank full and the same thing.
Brake fluid is hygroscopic and sucks moisture from everywhere. If you leave brake fluid sit for forever, it'll suck up a buncha water and rust your brake lines from the inside out.
dot 3 and 4 will. dot 5 wont but if you follow the service recommendations you should change it out before that can happen
In regards to changing out brake fluid how often is recommended? I changed mine out two years ago and about 6,000 miles.
Hawkeye56
Hawkeye56
Lots of variables here. 3 years is probably a good starting point, or whatever the manual says, or after every track day, or buy one of those test kits for it.
I'd be concerned that it would make the doors fall off.
