My 1995 Base Coupe has been out of service in a warm inside garage since November due to an injury that I had.
At that time, I disconnected the battery because I knew I wouldn't be driving until spring. Is it bad to leave it disconnected? Will any stored info disappear from the ECM?
@pltmgr Thanks. I'm actually a bit nervous about leaving it on a trickle charger plugged it all the time unattended. New battery, so I've sure that it will hold a good charge until I connect it.
Living up there in the cold winter, don't be surprised if your battery is dead but being inside a garage may have saved it. Put it on the charger for a few days before you totally drain it trying to start it.
Most of these cars will start at 10.5 - 11.0 V but yours is probably low sitting for three months.
Today trickle chargers are "smart" and will not overcharge/hurt your battery. I leave my non daily drivers on chargers 100% of the time and get 10-12 years from Walmart batteries.
