comments / suggestions
Old Feb 1, 2025 | 02:04 PM
GPNJ's Avatar
GPNJ
Default comments / suggestions
I am interested in purchasing this 1988 C4... the owner took meticulous care of it.. he said it needs absolutely nothing.. clean carfax.. 47,300 miles.. He is firm at $12,500.. does that seem like a fair/reasonable price? Thanks in advance.
Old Feb 1, 2025 | 05:44 PM
pltmgr's Avatar
pltmgr
Id say a little high for an 88 but looks like a nice car, If you really like it Id say get it.
Old Feb 1, 2025 | 05:47 PM
GPNJ's Avatar
GPNJ
Its in pristine condition.. zero issues.. always in a climate controlled garage. The guy really took amazing care of it.
Old Feb 1, 2025 | 06:48 PM
81c3's Avatar
81c3
So I believe yellow is a bit rare for C4's... other than that the stick is a plus and so is having 2 tops. Miles are good. He said it needs absolutely nothing.... Ask him the date codes on the tires, ask about the weather stripping, ask about heat and A/C operation. Ask about cruise control operation. Ask about the last time the trans was serviced, the coolant was flushed, if the rear end lube has ever been changed... Headlight operation, power seat operation.... If all this stuff checks out, then you might not have a whole lot of bargaining chips... None the less, Id try to offer at least a grand less and see what happens.... worst he can say is no,,,,
Old Feb 1, 2025 | 06:58 PM
GPNJ's Avatar
GPNJ
He has had the car for the last three years and he said that the coolant may have been changed before he purchased it and that it is as green as it can be. So he has never changed it himself. As far as the rear end, he said it goes by miles not years so it probably has not been changed.
Old Feb 1, 2025 | 08:47 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
that price for that quality of an early 4+3 car in yellow, that is what my local price would be. If you are looking for a very nice example in a sharp rare color grab it and enjoy.
Old Feb 1, 2025 | 08:58 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
In addition to what 81c3 said, I'd add ... do the overdrive gears in the 4+3 work?
Assuming you'll drive it and everything checks out, it seems reasonable to me
Good luck
Old Feb 3, 2025 | 02:52 PM
Corvette_Dez's Avatar
Corvette_Dez
Looking at pricing C4's and C5's are holding strong. The price seems very fair, especially considering mileage.
If you like the car, get a good PPI and pull the trigger.
Old Feb 6, 2025 | 07:49 AM
Oldpete's Avatar
Oldpete
First of all, it’s quite rare to find an 88 in unmolested, no hit condition. If all the sellers claims are verified buy the car. You would look long and hard to find another one like it
Old Feb 6, 2025 | 09:56 AM
SEVNT6's Avatar
SEVNT6
Hagerty shows a base '88 Coupe with a stick in #2 excellent condition at $18,500, $9,100 in #3 good...
Old Feb 6, 2025 | 10:33 AM
WVZR-1's Avatar
WVZR-1
I believe location is important. If local or close enough that you'll have no problems doing an inspection, doing a road test, and not requiring transportation means a good bit. If it's not local or close maybe it requires some thought.
To comments / suggestions
