Error Codes from ALDL
Old Feb 10, 2025 | 02:41 PM
ddarcy410's Avatar
ddarcy410
6th Gear
Default Error Codes from ALDL
Hello all. New to the forum, and Corvettes. I am tryingto check for error codes using the ALDL.
My understanding was to jump the A terminal (top far right terminal) to the B terminal ( 1st port to the left of the A port) turn the key to the on position without starting the car and the check engine light should flash. thus providing an error code depending upon how many flashes with pauses.
*** UPDATE *** replaced the bulb and now I have the codes I was looking for thanks everyone.
when I jump the A terminal to the B terminal my cooling fan comes on but no check engine light.
Do I need to check all of the wiring on this car ?
Old Feb 10, 2025 | 02:59 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
bulb
Old Feb 10, 2025 | 03:10 PM
ddarcy410's Avatar
ddarcy410
6th Gear
thanks I will check it
Old Feb 10, 2025 | 04:10 PM
IHBD's Avatar
IHBD
Pro Mechanic
Does the Service Engine Soon light come on with the key in RUN, ALDL not jumpered? If = NO, it does not come on, then bulb.
The cooling fan does come on with ALDL jumpered, engine not running. So the ECM is responding to the jumper.
You have a 1985 to 1993, but what is the exact year?
Old Feb 10, 2025 | 08:37 PM
typical boomer's Avatar
typical boomer
Found this little gem in a thrift store for $2.00. It's just a glorified paper clip but it's probably easier to insert blind. Guess I'll know later as I have not used it yet.
I have an '84 so no use for the ABS switch.
The third pin is for ABS i'm guessing. Probably blank on my ALDL socket.
Old Feb 11, 2025 | 10:05 AM
ddarcy410's Avatar
ddarcy410
6th Gear
I just acquired a 1985 Chevy Corvette.
I hadn't noticed the Service Engine soon / Check engine light. as one other user suggested possibly the bulb is out.
I will carefully replace the bulb and recheck. good to know that jumping A & B will turn the cooling fans on and it is not a crossed wire.
Got a loit of learning to do. will be ordering a shop manual shortly which should assist some.
thanks
Old Feb 11, 2025 | 07:37 PM
Kevova's Avatar
Kevova
Don't be surprised if bulb and bulb socket are both missing. That is how some techs fixed pesky ses lights permanently.
To Error Codes from ALDL
