Side bolsters
Old Feb 10, 2003 | 01:37 PM
OURRUBY's Avatar
OURRUBY
Spending his inheritance
Cruise-In VIII Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Side bolsters
We were working on my son's Ruby seats (vetteweiser) and then checked mine. Seems the side bolsters don't work, along with the air pumps. I know why the air pumps don't work, but can't figure out the side bolsters. They are electric right? The driver's side has a clicking noise when I push the button but the passenger side makes no noise. Any ideas as to what is wrong with the bolsters? Also, where is the best place to get the pump repair kits? TIA Perry :seeya
Old Feb 10, 2003 | 01:44 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Side bolsters (OURRUBY)
Try Tech Tips. I also have an article that may be of some help. If you would like it let me know. roman67844@cs.com
[Modified by lou sylvestri, 10:48 AM 2/10/2003]
Old Feb 10, 2003 | 03:33 PM
Mikez40's Avatar
Mikez40
For the pump, just get some rubber dishwashing gloves and cut out a gasket.
As far as the side bolster switch, get some contact cleaner at a computer store and spray into the switch. that should fix the switch.
I have owned 3 1993 Vettes and have done this on all 3 of them and its had worked fine.
[Modified by Mikez40, 2:35 PM 2/10/2003]
Old Feb 11, 2003 | 12:38 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Side bolsters (Mikez40)
[QUOTE]For the pump, just get some rubber dishwashing gloves and cut out a gasket.
QUOTE]
Well, looks like dad and I have our tuesday project :thumbs:
Old Feb 11, 2003 | 04:59 PM
OURRUBY's Avatar
OURRUBY
:cheers: Mikez40 for the good tip. Vetteweiser and I fixed the seat pumps in our Rubies this afternoon. Took about 2 hours to do the four of them. Will look at the bolsters another time. :seeya
Old Feb 11, 2003 | 05:04 PM
vetteweiser
Cruise-In V Veteran
and retrieve my lost screw driver :rolleyes:
To Side bolsters
