Interior dimmer switch issues?
Old Feb 13, 2025 | 03:12 PM
Ryder.Juss's Avatar
Ryder.Juss
2nd Gear
Default Interior dimmer switch issues?
Hi all, my 93's interior lights have been acting up. The issue seems primarily when my headlights are on. All of the interior lights will go completely dark, from the dash to the door lights to the backlighting on the head unit, everything is black. Then I play with the dimmer adjuster on the headlight **** and it will go back on. It seems if I put it in the fully clockwise position and push it into the dash with some force, the lights will stay on. I'm guessing the component behind the adjuster is bad and needs replacement? It would be greatly apricated if anyone has info on this (:
Thank you!!
Old Feb 14, 2025 | 06:26 AM
Incorvettei's Avatar
Incorvettei
Did you try cleaning the contacts in the switch?
