L98 upper intake and tubes torque
Old Mar 1, 2025 | 08:31 PM
johnfin's Avatar
johnfin
Default L98 upper intake and tubes torque
How come the specs are not in the factory book?
Old Mar 2, 2025 | 01:32 PM
arbee's Avatar
arbee
h
Probably because the people who drafted the FSM took for granted that people wielding the wrench would know what level of tightness was required. This site seems to have a fetish with
"what is the torque value of........." Certain components require a specified torque value to maintain straightness and accuracy. Heads, valve bodies, pump halves, even aluminum wheels all fit this category. Inconsistent values would result in warping. However, the vast majority of fasteners on a car just require common sense. Over the years, people have asked "what is the torque" of everything from battery posts to license plate bolts. Who GAF? The value for all of these is "tight". The amount of force required to tighten a 5/16 bolt is far different than what is required for a 1 inch bolt. Learn it! When was the last time you seen a tech walking around the shop with a torque wrench and a booklet of "torque values"?
Old Mar 2, 2025 | 01:42 PM
old stingray's Avatar
old stingray
One thing to remember to tighten the bolts in the right sequence and not over tighten.
Old Mar 2, 2025 | 07:53 PM
johnfin's Avatar
johnfin
There is a sequence for the intake tubes? Never seen that.
Old Mar 15, 2025 | 06:16 PM
johnfin's Avatar
johnfin
No reply to a sequence? Grumpys says 25lbs on the runners internet says 18lbs
To L98 upper intake and tubes torque
