'87 Alternator??
Old Mar 6, 2025 | 12:17 PM
87_blue's Avatar
87_blue
4th Gear
Default '87 Alternator??
Hey Guys! Anyone have a link to the best '87 c4 alternator replacement (with minimal special work needed to install)? And link to belt to replace current one?
Previous threads are outdated/unclear.
{Ran into scary issue last week - car was running and I heard the engine/electric fluctuating intense --> weak. Then suddenly it went dead -- no light, no engine. Needed a boost to turn the car back on and get it home. Definitely an alternator issue, right?? It seemed to be holding above 13v though...}
ALSO - my A/C compressor is shot - do I need to repair this before putting in the alternator?
Thanks!!!
(for example - is there a difference or recomendation between these? https://www.topflightautomotive.com/...direction=desc)
Old Mar 6, 2025 | 01:42 PM
braeburn22's Avatar
braeburn22
Check out the CS144 upgrade/replacement, well worth doing almost direct replacement for CS130, you use a CS144 alternator for a 1997 Camaro or LT1 Corvette.
Old Mar 6, 2025 | 06:10 PM
87_blue's Avatar
87_blue
4th Gear
Great, thanks so much!
Rookie question here - is there also a notable difference between CS130 with 120amps (instead of 105) v. 144? And would the 144 fit in the car without too many annoying mods?
Old Mar 8, 2025 | 02:29 AM
braeburn22's Avatar
braeburn22
Hi,
I fitted mine in about 20 minutes, the only modification required is the upper mounting tab that you need to file down by about 3mm, every thing else is a straight fit, if you search the forum for cs130 to cs144 upgrade there is lots of information.
To '87 Alternator??
