84 C4 digital gauages
1) Alternator failure. This can include the voltage regulator which is built into the alternator. Bad voltage regulator can undercharge or overcharge if defective.
2) Loose or corroded contacts.This includes battery, alternator and starter motor.
3) Loose or corroded grounds. There are many locations for grounds.
If you don't already have a FSM I recommend one ASAP.
Second issue is probably related the the fuel tank and the fuel level float. It is probably stuck in the full position. It is easy to gain access. Again a FSM will be very helpful.
https://www.rockauto.com/en/moreinfo...=10335&jsn=498
Also the Electrical Supplement is very useful.
https://www.rockauto.com/en/moreinfo...=10335&jsn=499
