Battery/alternator issue
Old Mar 29, 2025 | 02:46 PM
Goin For Gold's Avatar
Goin For Gold
Cruising
Default Battery/alternator issue
So I had an issue with the battery in my 85 the other day. I let the car idle for 15-20min and noticed smoke coming out from the hood, I turn the car off and open the hood to find the battery boiling and steam coming out from the vents. The battery was untouchable as it was wayyyyyyy too hot. I’ve been having trouble with a battery drain and have ruled out that it has something to do with the LCD. When I pull the fuse the drain is no more. So bought a new battery and did a volt check on the battery terminals when idle and found to have 15.6v, after a couple revs it dropped to 15.2v. The dash read 14.3v at this time. From my research the battery is supposed to be at 14.7v at idle. Is this too high for the battery?Does this sound like an alternator/voltage regulator problem? Should I replace or rebuild the alternator? All thoughts appreciated!
Old Mar 29, 2025 | 04:23 PM
pltmgr's Avatar
pltmgr
Id take the alternator to chain auto parts store for testing.
Old Mar 29, 2025 | 05:40 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
time for new alternator
Old Mar 29, 2025 | 11:14 PM
IHBD's Avatar
IHBD
Pro Mechanic
Replace the regulator. It's easy to do, and no special tools required. My 85 has its original alternator, but is about to receive its 4th regulator in 40 years. The original was making RFI, the next two went "high voltage".
There's a power transistor in the cluster that fails, and the cluster doesn't "turn off". The draw on the LCD fuse is about 500ma if the transistor has failed. Draw should be about 50ma, IIRC. << My 85 has done this too.
EDIT/ADD: Yesterday when I wrote this response I was anticipating driving my 85 next weekend to a show and shine I attend a few times a year. Next Sunday is Corvette Marque Day. Typically there are 500 to 1,000 Corvettes at this event. When I last drove the 85 in December, it was experiencing high voltage so it needs another regulator. Today's project is get the 85 out, clean it up a little, and change the voltage regulator.
Last night I looked up a regulator on O'Rileys and came up with a Standard Motor Products VR-111. It was in stock, and they were open until 2300, so I got in the truck and purchased one. Including R&I of the alternator it won't take an hour, and my 40 year old OO 1985 will still retain its born-with number matching alternator. Cheers.
Old Mar 30, 2025 | 06:56 AM
Ed Johnson's Avatar
Ed Johnson
Make sure to wash the battery tray and under it if you has any acid spill out.
To Battery/alternator issue
