87 c4
Old Apr 10, 2025 | 04:35 PM
227KC4's Avatar
227KC4
Default 87 c4
Approx cost to check oil pressure sensor
Old Apr 11, 2025 | 05:05 AM
ls777z's Avatar
ls777z
As rates are different all over the country I'm sure a dealer will charge you about an hour, hour and a half, of their Corvette labor rate (not to be confused with normal car labor rate). This consists of: bringing the car in, looking it over for other $$$ making things that need repair/replace, hooking up whatever diagnosing device needed, performing the test, checking to see if they have the part in stock or need to have it shipped in, doing a repair estimate based on the results, getting your approval or declination, actually install the repair/replace part, or not, and then driving the car back outside. An independent garage might be cheaper, but again, the labor rates are different everywhere.
Old Apr 11, 2025 | 08:12 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
First off, what's the problem with it?
To 87 c4
