Driver's window stuck
Old Apr 19, 2025 | 03:22 PM
russmike's Avatar
russmike
3rd Gear
Default Driver's window stuck
Hi, I have a 1993 Coupe which I purchased this February. A couple of weeks ago, after a drive, the driver's window will only come up about an inch above the weatherstripping. It will go down, but up no farther than that. The motor powers it up and then it just stops. I removed the door panel - can't see anything blocking it or stopping it's progress. I cannot pull it upwards at all, even while operating the window switch. Any advice?
Old Apr 19, 2025 | 07:48 PM
dburgjohn's Avatar
dburgjohn
sounds like you need a new motor or complete regulator
Old Apr 19, 2025 | 11:37 PM
2011KLR's Avatar
2011KLR
Althoughthis is a screensnip of the 1988 FSM the 93 will surely be similiar. Check out the grey box mention of an internal circuit breaker. It is possible that the mechanism is binding and tripping the circuit breaker. Or the motor could be going south and tripping on its own.
Old Apr 20, 2025 | 09:25 AM
dburgjohn's Avatar
dburgjohn
if you grab and lift while hitting the switch does it go up farther?
Old Apr 20, 2025 | 05:52 PM
russmike's Avatar
russmike
3rd Gear
So, I checked out the switches - all good; cleaned them well. The motor does work in the down direction and for a bit in the up direction - so it makes me think that something is binding in the regulator. Before I tackled that job, I decided to take a drive to remind myself how much fun this car can be. While driving, I absentmindedly hit the up switch - and after a hiccup, it went up! I'm still going to dig into why, but now I can lock it, not worry about rain, etc... I will probably take the other door card off since there is also a problem with the locks.
Old Apr 20, 2025 | 09:03 PM
2011KLR's Avatar
2011KLR
Those 80s switches were cool lookin but dont always age well.
When you dig into them, swap the switches. If the problem moves.....
Dang. Yours arent both in the console like the 88s. If it were me, id just swap in a new switch and drive.
To Driver's window stuck
