Rear Toe Link Assembly
Old May 1, 2025 | 12:45 PM
Limp's Avatar
Limp
Default Rear Toe Link Assembly
Is there some maintenance that can be done on the Toe link assembly where both rods meet in the part bolted to the 3rd member?? Can't find anything at parts houses or with a search?? The boots are rock hard and I would at least like to change those out but again, Can't find any parts? thanks for any help...... 85 C4
Old May 1, 2025 | 01:18 PM
Aardwolf's Avatar
Aardwolf
It can be swapped out for a later year that might be in better shape. The cups inside are plastic and can wear out. It needs to be taken apart and regreased. For the boots I don't have a part number
Old May 1, 2025 | 04:05 PM
Limp's Avatar
Limp
Thanks for the pic.... Do they just pull out when you pop off the caps??
Old May 2, 2025 | 11:54 AM
Aardwolf's Avatar
Aardwolf
Yes no problem unless corrosion.
To Rear Toe Link Assembly
