'94 Brake Booster Replacement??
Old May 24, 2025 | 09:50 PM
Dougs63's Avatar
Dougs63
2018 C4 of Year Finalist
2016 C4 of Year Finalist
2015 C4 of Year Finalist
Default '94 Brake Booster Replacement??
Seems my original '94 Brake Booster has gone kaput (booster is hissing, car hard to stop, etc.). Given I'm a little stuck on originality - two questions:
1. Who sells an original '94 plastic brake booster?
or
2. Is there anyone out there that would rebuild mine?
Actually my preference would be to rebuild my original. While I'm in there, I also plan to replace the master cylinder.
Thanks as always for any responses.
--Doug
Old May 25, 2025 | 10:31 PM
Impala Balko's Avatar
Impala Balko
I replaced my booster a year ago and all i could find is the metal ones... I don't know if there are any of the OE plastic ones around unless you buy used
Old May 26, 2025 | 10:21 AM
Calico Jack's Avatar
Calico Jack
Navigator
I just finished this project. I’m in CA and no one had one local. Plastic or metal. Had to have one shipped from Florida thru Orielys. Plastic unit, 200 bucks. It work correctly and looks close. Working under the dash was the hardest part.
Old May 27, 2025 | 01:32 AM
topfuel67's Avatar
topfuel67
Is your car auto or manual transmission? If manual the metal ones won’t fit and you have to find a used original. While doing the booster is a great time to do plugs. So much easier to get to the plugs on the driver side rear.
To '94 Brake Booster Replacement??
