C4 1996 LT1 base. Starter failure
Old Jun 14, 2025 | 12:48 PM
EdRoc0515's Avatar
EdRoc0515
Default C4 1996 LT1 base. Starter failure
After weeks of trouble shooting the ignition system, the mobile mechanic removed the original starter, O’REILLYs bench tested. FAILED. New starter going in Monday.
Starter relay, both replaced, ICM , ignition coil replaced. Crank position sensor seems to be ruled out. It might start after all!!
Thanks for all your help
Starter failed at O’REILLY’s
Original starter
Original starter
Original starter
Original starter
Original starter
Original starter
Old Jun 14, 2025 | 04:02 PM
pltmgr's Avatar
pltmgr
Good luck to you. Had a lot of trouble with a new starter in my 96. Rebuilt the solenoid of the original starter and everything is fine.
Old Jun 14, 2025 | 06:37 PM
EdRoc0515's Avatar
EdRoc0515
Default Rebuilding the starter solenoid
Oh man, hope I don’t have to do that.
To C4 1996 LT1 base. Starter failure
