C4 Corvette blinker issues.
Old Jul 12, 2025 | 08:59 PM
EFSS87C4's Avatar
EFSS87C4
1st Gear
Default C4 Corvette blinker issues.
I have a 1987 C4 Corvette so my blinkers weren’t working so I checked the fuse for the blinker and the fuse was burnt out so I put a new one in there and they started working again and it’s like as soon as I put it in gear or touch my brake pedal they stopped working again and blew the fuse so I grabbed a new fuse just to make sure everything was all right, and I tried it again and the same thing happened again. I was on my way home today and I was starting to get dark and I open my headlights and my hazards weren’t flashing both arrows are on. I just need my blinkers to work. I’m not sure what to do anymore. Why do I keep blowing fuses?
Old Jul 13, 2025 | 06:47 AM
Incorvettei's Avatar
Incorvettei
You keep blowing fuses because there is obviously something wrong. I would look for a ground issue
Old Jul 13, 2025 | 06:53 AM
ls777z's Avatar
ls777z
aftermarket radio? could be there is an exposed section of wire under the dash that when you hit the brake pedal its shorting out. long shot but you never know...
To C4 Corvette blinker issues.
