Rear abs sensor damage.
Old Jul 17, 2025 | 08:13 AM
greatscott73's Avatar
greatscott73
Default Rear abs sensor damage.
Chasing an abs issue on my 89 convertible and found the tip shaved on the RR wheel speed sensor. I would suspect a bad wheel bearing, but it seems tight. Could have been changed before I bought the car. Any other issues that might cause this? Seems unusual that the reluctor wheel is on the axle stub instead of the bearing.
Old Jul 17, 2025 | 02:14 PM
Phobos84's Avatar
Phobos84
Unless something has changed, what sucks about these is you can't buy new sensors. You're stuck buying used off eBay or removing the ABS altogether.
Old Jul 20, 2025 | 12:32 PM
greatscott73
Went to remove the wheel bearing and found the nut, that should be torqued to 164 ft. Lbs, finger tight. This allowed everything to move around more than designed. Thought I should check the other side, and found the same thing, although the ABS sensor isn’t shaved like the passenger side. I guess people ignore torque specs for some unknown reason.
To Rear abs sensor damage.
