NEW WHEELS
Old Feb 16, 2003 | 05:34 PM
Secondvet's Avatar
Secondvet
Default NEW WHEELS
Well i see a lot of guys getting new wheels with good and not so good input. Hope i have a positive experience, i just ordered (4) 17x9.5 chrome ZR1 replica from CWS they are all 54mm offset. I plan on running 285's all around at least i can rotate front to back on same side. Any body see any problems with that setup. :chevy
Old Feb 16, 2003 | 07:57 PM
bogus's Avatar
bogus
Default Re: NEW WHEELS (Secondvet)
should work just fine!
personally, I would use 275's, but thats just me.
Old Feb 16, 2003 | 09:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
:cool: Let us know if you're satisfied with em.
Old Feb 16, 2003 | 09:53 PM
vader86's Avatar
vader86
Default Re: NEW WHEELS (CentralCoaster)
:cheers: :cheers:
Old Feb 16, 2003 | 10:20 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: NEW WHEELS (bogus)
:iagree: Just my .02
Old Feb 16, 2003 | 10:27 PM
Izover4u's Avatar
Izover4u
i thought 56mm was optimal offset for the 9.5 wheel... when I looked at GM specs 56mm was used with the 9.5 wheel and 50 with the 11inch wheel...
I ordered a set from a vender and his 9.5 was 53mm and it stuck out past the fender :mad
Be sure to post pics and info when u get them...
I was considering CWS to order my set from... :cheers:
Old Feb 19, 2003 | 01:02 PM
35th's Avatar
35th
Default Re: NEW WHEELS (Izover4u)
Hope U'rs work out like mine did, I got the rims and tires 4 $1600.00. I didn't think that was a bad deal :thumbs:
Old Feb 19, 2003 | 01:04 PM
atotalnincompoop's Avatar
atotalnincompoop
285's wow!! :cool:
Old Feb 19, 2003 | 08:26 PM
red-y's Avatar
red-y
:cool: I have seen this - you will like it. :steering:
Old Feb 20, 2003 | 01:28 AM
TA's Avatar
TA
285s will fit fine. I'm also running them front and rear.
Old Feb 20, 2003 | 01:50 AM
96CollectorLT4's Avatar
96CollectorLT4
I know it's not a big step up in size from 275's but would 285's fit on my stock CE rims up front? Stock offset is how much?
:seeya
To NEW WHEELS
