1988 cold Start Question
Old Aug 27, 2025 | 04:58 PM
mlk1950's Avatar
mlk1950
Cruising
Default 1988 cold Start Question
Hi all, I own a 1988, 350 L98, that is only driven in the Spring and Summer months. I am thinking of installing a Cold Start Valve Block-off kit and upgrading the Prom Code to $6E to eliminate the Cold Start all together. My question is, what issues might arise by doing so?
Old Aug 27, 2025 | 05:50 PM
IHBD's Avatar
IHBD
Pro Mechanic
Does it start reliably either hot or cold, now? If =YES, why try to fix something that isn't broken?
Old Aug 27, 2025 | 07:46 PM
mlk1950's Avatar
mlk1950
Cruising
Sometimes yes and sometimes no. I have had lots of problems with this car and am just trying to eliminate possible problems from the equation.
Old Aug 27, 2025 | 11:29 PM
RustyDuster's Avatar
RustyDuster
I can empathize with having lots of problems with the car, but I ironed them out over the past few months. What are you experiencing?
Old Aug 28, 2025 | 01:55 PM
mlk1950's Avatar
mlk1950
Cruising
First off, thank you for the help. Ok, just recently it would start run a few seconds then die. I would do that dance about six or seven times and then it would stay running. Now it stopped doing that. Then driving over to my mechanics shop it randomly would die while driving and then would come back to life. It did that 3 or 4 times. Now it stopped doing that. It's been scanned twice.So far I have installed these items new. Coil, ignition module, cap, rotor, fuel sender, fuel pump, fuel filter. Checked the O2 Sensor which checked out fine. Did a fuel pressure check twice. The second time was over night and had a considerable bleed down on that one which tells me a leaking injector. Possibly the ninth. I do have a new set of Delphi 22lb injectors on the way. All I wanted to know was would doing away with the ninth injector have any bad consequences.
Again, thanks for the help.
Old Aug 28, 2025 | 06:09 PM
IHBD's Avatar
IHBD
Pro Mechanic
Old Aug 28, 2025 | 10:43 PM
mlk1950's Avatar
mlk1950
Cruising
Thank you.
Old Aug 30, 2025 | 12:45 AM
RustyDuster
I have the same car and setup as you. Did you pinch off the fuel return line? Also, check that throttle position sensor to make sure it's at .54 V . You can back probe the top and middle wire while key in position #2. These are OBD1 so is your mechanic scanning with the proper cable and software? It isn't a standard OBD2 setup. I have Win ALDL so I like to calibrate the TPS based on what the ECU is actually seeing rather than my multimeter which is sometimes a little off.
You've changed alot of parts, and with these cars it's necessary to DIY but it sounds like you need to perform some more diagnosis here first...
Old Aug 30, 2025 | 09:33 AM
mlk1950's Avatar
mlk1950
Cruising
Thank you, that's some good info. I took it out yesterday for a drive and all seemed good. Then, I pulled up to a stop sign to make a left turn. When I went to start my turn, stepping on the throttle, it fell on it's face for an instant and then came back to life again. The thing is, this car can't be trusted, especially pulling out onto a busy highway. What you said about the TPS makes sense and I'll mention that to my mechanic, who is very good. This thing has has him scratching his head. These corvettes are definitely a different breed of cat. The scanner he is using on this is an OBD1. He has taken this thing out and drove it several times. Of course it won't die for him and seems to run real good.
Old Aug 30, 2025 | 11:42 AM
IHBD's Avatar
IHBD
Pro Mechanic
Old Aug 30, 2025 | 11:52 AM
mlk1950's Avatar
mlk1950
Cruising
3/4. Just filled it up a few days ago with premium unleaded.
Old Aug 30, 2025 | 11:01 PM
RustyDuster
I'll readily admit that I have been working on cars since I was 12, turning a wrench with my old man on his Mopars. I went on to BMWs and then as of a few months ago purchased a C4. There have been times when I have wondered if this car was cursed, but I have learned alot as a result and am pretty happy with the way it's running now. These cars went digital before the rest of the world did and they sit at a critical transition in automotive design when the manufacturers were moving away from carbs and into tuned port injection. You and your mechanic will learn alot before it's dialed in.
Also, many of the issues I encountered with the car were due to improperly executed repairs, which included a missing ground strap in the distributor cap, wrong spark plugs, the list goes on. I did not have much faith in mechanics going in and now it's practically nill, at least not around here!
Old Aug 30, 2025 | 11:07 PM
RustyDuster
Re: the TPS, there should be two small bolts holding it in place. They should be snug and the voltage to be .54. Sometimes they can become loose or the TPS knocked out of position during work being performed near or on it. I lost those two small, crescent shaped metal shims which help hold it in place but its done ok so far without them..
Old Aug 31, 2025 | 04:28 AM
mlk1950's Avatar
mlk1950
Cruising
What a coincidence, I used to drag race a Mopar. It ran mid 11s and was a blast. It was a 1978 Plymouth Volare. I put a 440 ci and a Torque flight in it. Did all the work myself except the machine work on the 440. I did the engine assembly and even pocket ported the heads. I wish this vette was as fun to work on as that was.
Old Aug 31, 2025 | 02:28 PM
RustyDuster
I remember the days when guys were looking for those 440's in motorhomes and putting them in their cars! It was simple and all intuition back then. But, you'll learn to work on the Vette and grown to like it eventually.. maybe... we hope..
To 1988 cold Start Question
