Engine stalling
Old Aug 30, 2025 | 01:52 PM
Huutchh's Avatar
Huutchh
Navigator
Default Engine stalling
Evening folks,
So I have a 1991 that's had a lot of work done to it, cam, headers, throttle body, LT1 manifold. New clutch.
I've just fit Bosch 30lb injectors, fuel pressure regulator and a chip from PCM so everything that's been done works as it should.
I've took it out to test drive it and when driving and decelerating say to a roundabout or a set of traffic lights, it will cut out, not every time but sometimes. It starts again no problem when in motion or when I've cruised it up to the lights. I think its when I drop the clutch to downshift through the gears...
Is it the clutch pedal? I must say growing up in the UK manual cars are the car you drive most of the time so I've drove manual for over 15 years. The Corvette has to be the worst clutch I've ever drove. So there has to be something wrong.
The fluid is max.
Many thanks.
