drive belt
Old Oct 10, 2025 | 05:49 PM
spluce's Avatar
spluce
8th Gear
Default drive belt
A friend of mine was given a 95. My job is to make it run and stop. The a/c pully is missing so I was wondering if they make a belt that will work with the deleted a/c compressor.
Also the e-brake is stuck on, any common problems with that system? The handle has no tension on it when pulled up, I probably wont even get around to looking at this car as I have two other projects that need to be done first. Not sure how I will get it into the shop with e-brake problem, can't push it, can't jack up the rear and move it that way, it's sitting on gravel.
That will be the first challenge
Old Oct 10, 2025 | 07:24 PM
2011KLR's Avatar
2011KLR
Watch this video. Hopefully...... this is all that you're dealing with.
