Valve guide seals.
Here's some things to keep in mind regarding 'valve stem seals':
When the engine is running, exhaust pressure is positive. I'm not sure how helpful positive-lock stem seals are on the exhaust.
The o-ring seal seals the bottom of the retainer to the valve stem. Oil can't run out the bottom of the retainer, follow the valve stem and run past the guides (particularly exhaust) when the engine is not running. << This is what causes the smoke on start-up.
The "umbrellas" on the exhaust divert any oil that gets past the o-ring, or gets on the stem from splash when the engine is running away from the stem and valve guide.
The intakes benefit from positive-lock stem seals. But still install the o-rings.
Positive-lock seals reduce the retainer to guide clearance. If you are running 1.6 rockers, or non-stock camshaft with more lift than OEM, double-checking retainer to guide/stem seal clearance is a good idea.
I've done a bunch of V8 and V6-90 stem seal jobs using the GM kit that has the o-rings and 2 sets of exhaust umbrellas (there are two exhaust stem diameters for 5.7L) and positive-lock seals for the intakes. One of the engines I put the GM kit in was the 93 Typhoon that I owned for 26 years. I put stem seals in it shortly after purchase in 2000-ish (at about 80,000 miles) and it was not smoking on start up 23 years and 100k miles later when I sold it.
