Does coolant always flow through the heater core.
Old Nov 4, 2025 | 02:03 PM
Vickythevett's Avatar
Vickythevett
Default Does coolant always flow through the heater core.
Just a quick question, does coolant always flow through the heater core ? I have a 1984 corvette and for the 6 years I’ve owed it I never tried the heat. Is it a bad idea to try the heat? If coolant doesn’t flow through it I don’t want to mix what ever dirt and probably corroded stuff that’s inside the heater core if fluid doesn’t run through it. But if fluid always runs through the heater core I won’t mind trying out the heat.
Old Nov 4, 2025 | 05:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
yes. until you turn the AC on and the shut off valve is turned on
Old Nov 4, 2025 | 06:27 PM
IHBD's Avatar
IHBD
Pro Mechanic
^^ NO. ^^
The 84 and 85 have a heater valve that blocks/bypasses the core when the temp control is at full COLD or if the system mode selection is A/C MAX.. Any time the temp control is not at full COLD, and not in MAX, the valve opens and flow is directed through the core.
If the heat in the OP's 84 has not been "used" for 6 years, the concern would be that the valve is stuck, and/or that it will begin to leak once it is cycled. I don't feel that 'sediment' in the core is an issue.
Old Nov 4, 2025 | 06:52 PM
Nowhere Man
Originally Posted by IHBD
^^ NO. ^^
isn't that what I said. All GM factory AC has a coolant shut off valve when the AC is turned on.
Old Nov 4, 2025 | 07:15 PM
Vickythevett
^^ NO. ^^
thanks for the input. My hot cold switch has been in the middle for all this time, it moves no problem. I was just mainly concerned if coolant has been flowing through this whole time if I shouldn’t turn the heat on. But since I know coolant has been flowing since I leave my hot cold switch in the middle I will test out the heat. Thanks again
Old Nov 4, 2025 | 07:16 PM
Vickythevett
thanks for the input! Was just worried that if it didn’t have coolant running through it this whole time it might leak or be rusty, but since I leave my hot cold switch in the middle coolant should have been flowing through so I’m good, thanks again
Old Nov 4, 2025 | 08:29 PM
IHBD's Avatar
IHBD
Pro Mechanic
No, that is not what you said, and for the 84 Corvette it is not true. Actually for a whole bunch of GMs it is not true because valves are more likely to be absent than present.
The 84 only turns off the core flow when the A/C is in MAX..When the A/C is in NORMAL, you can increase the temperature of the A/C by moving the temp lever to the right. Moving the lever turns on the heater flow.
And NO. "Not all GM factory AC has a coolant shut off valve." The C4 no longer has a heater flow valve after I believe 1987. I KNOW that my 1990 ZR-1 and my 1992 do NOT have heater core valves.
So again, you're making untrue statements. Not "all GM AC have heater valves." None of my s-series (about 15 of them) have had valves either.
Old Nov 5, 2025 | 10:42 AM
FAUEE's Avatar
FAUEE
Agreed, they definitely removed the valve at some point. My 92 does not have one either.
Old Nov 5, 2025 | 12:59 PM
RWDsmoke's Avatar
RWDsmoke
My 86 still has a heater water valve. It is vacuum operated and it is always open when the engine is off and no vacuum. If working properly, it takes several seconds to close when vacuum is applied, so for a few seconds after starting, water will flow through the heater core even when set on max cool.
To Does coolant always flow through the heater core.
