Help Diagnosing Noises
Old Nov 6, 2025 | 03:47 PM
AGuyNamedBean's Avatar
AGuyNamedBean
Cruising
Default Help Diagnosing Noises
After driving my 85 C4 for a while, I started noticing a couple sounds. They are two distinct noises, but one is semi-constant and the other isn't.
One is a noise I can only describe as metal discs spinning against each other, it happens only while accelerating and gets louder the harder I press the gas. It doesn't happen when cruising, or revving in park/neutral.
The other is a horrible grinding/crunching sound that happens mostly when accelerating after turning. The guy at Top 5 Auto Repairs has a perfect recreation of what I hear. at 28s
From what I've looked up, I'm thinking it's something with the Differential and/or Transmission, but I don't want to be too hasty since I'm no expert.
Old Nov 6, 2025 | 07:22 PM
RustyDuster's Avatar
RustyDuster
Your video doesn't work but for sound #2 that occurs when accelerating while turning, take the car out to an empty parking lot or another area where there is plenty of space and move your steering wheel back and forth while accelerating and/or moving forward. If the sound gets louder when the car is leaning either right or left then many times it could be the wheel bearing on that side. That's the old school mechanic's way of identifying which bearing is bad.
I'll let someone else speculate on sound #1.
Old Nov 6, 2025 | 07:28 PM
AGuyNamedBean
Cruising
I don't think it's a bearing, the bad ones were replaced along with the brakes. It's also not a continuous noise, and doesn't always happen.
Old Nov 6, 2025 | 07:54 PM
typical boomer's Avatar
typical boomer
The U-joints on my '84 sounded like noise #1.
https://www.corvetteforum.com/forums...-were-bad.html
To Help Diagnosing Noises
