Thread in Sealant
Old Nov 15, 2025 | 09:08 AM
arbee's Avatar
arbee
Default Thread in Sealant
I guess the saying "You're never too old to learn something" is a fact. Yesterday, while having my morning coffee and surfing different websites, I came across something that kind of stopped me.
Despite dozens of years and countless rebuilds of engines, transmissions, rear ends etc. as a hobbyist, I had NEVER seen or heard of putting a thread in the sealant of two flush mating surfaces (where no gasket is used) to prevent the sealant from completely squishing out. It is there to provide a minimum sealant thickness. I understand that Lycoming even stipulates its use in some of their aircraft engine rebuilds. As I said, despite thousands of hours of researching different procedures, I had never come across this. On its face though, it does make sense. It calls me to try it on my next FWD transmission. Any input - pro and con?
Old Nov 15, 2025 | 09:51 AM
Rod Schneider's Avatar
Rod Schneider
Using thread in this manner is standard practice in most aircraft piston engine case mating surfaces that don't use a gasket. The procedure is to use Aviation Permatex sealer, which is non-hardening, and running a silk thread around the mating surfaces. More recently, the use of Loctite 515 anaerobic sealer with no thread has become the preferred method, as it does a better job of sealing without any seepage or leaks. I am a licensed aircraft technician and I've done a few engine overhauls using the Loctite 515 and I've had no issues with seepage or leaks.
Old Nov 15, 2025 | 10:05 AM
arbee's Avatar
arbee
Is there any guidelines as to what to use? Is there a product specifically made for this purpose? Wondering if something like dental floss would work.
Old Nov 15, 2025 | 10:16 AM
Rod Schneider
Permatex Aviation Grade 3D
and
#641543 Silk Thread
and
#646942 Gasket Maker
or
Loctite Gasket Eliminator
515 Sealant
For Distributor information call:
Permatex Customer Service @
Phone: 1-800-641-7376
May be purchased through
your local TCM Distributor
Loctite Customer Service @
Phone: 1-800-243-4874
Crankcase parting face, oil pump
covers,
This is copied out of the Continental overhaul manual. It's a very specific silk thread and Permatex. Honestly, you'd be far better off just using the Loctite.
Old Nov 16, 2025 | 02:36 AM
JETS C3-C4's Avatar
JETS C3-C4
Very interesting information.
A silk thread would be a lot smaller than dental floss. I would not use floss. Floss also contains wax and would not tolerate heat.
That's my .02 for what it is worth.
Old Nov 19, 2025 | 12:48 AM
RustyDuster's Avatar
RustyDuster
Thanks Rob, this is interesting! I'm curious how did you keep the silk thread in place on the surface while laying the bead of sealant? seems like it would get squirrely and stick to the bead and misplaced easily.
Old Nov 19, 2025 | 01:07 AM
arbee's Avatar
arbee
Pretty sure the trick is to lay down the sealant first.
Old Nov 19, 2025 | 08:54 AM
Rod Schneider
Yes! You lay down a thin layer of sealant and then lay the thread down onto that. It can get a little tricky if you aren't careful........
Old Nov 20, 2025 | 07:49 AM
84 4+3's Avatar
84 4+3
I'll have to keep this in my back pocket for some of the flanged parts at work the "mechanics" can't seem to get sealed.
To Thread in Sealant
