1995 C4 stalling
Old Dec 13, 2025 | 12:03 PM
Rick Mascia's Avatar
Rick Mascia
7th Gear
Default 1995 C4 stalling
My 1995 C4 starts up and run great and for no reason stalls and won't start. After 30 minutes I will start and run fo awhile then stalls and won't restart
Old Dec 13, 2025 | 09:28 PM
CorvetteRules's Avatar
CorvetteRules
How long does it run before stalling. Is it stalling when going into closed loop or before??
Old Dec 14, 2025 | 02:23 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Failing ICM.
Old Dec 14, 2025 | 11:02 AM
kirkm's Avatar
kirkm
Check the fuel rail pressure. The fuel filter sock on my 1995 started dry rotting and pieces started getting sucked into the pump, clogging it up. Still had some pressure but not enough for the car to run. After the car sat for a while, it would start again. Replaced the pump and sock, hasn’t run better in a long while.
Old Dec 14, 2025 | 12:28 PM
Ed Johnson's Avatar
Ed Johnson
Reposted
Old Dec 14, 2025 | 12:30 PM
Ed Johnson's Avatar
Ed Johnson
Default Stalling
have you checked for trouble codes stored in computer ?
Old Dec 15, 2025 | 06:58 AM
MatthewMiller's Avatar
MatthewMiller
This sounds very much like something in the ignition system is failing when it gets hot. The someone above already mentioned the ICM, but the opti sensor can also fail in this mode. When it won't start, you need to use a noid light to see if the injectors are getting their pulses from the PCM. If not, it's the opti. If so, it's likely the ICM.
To 1995 C4 stalling
