Engine stalls when ECM kicks in ?
Now that he is saying its a no start it throws everything out the window. He could short pins on his OBD to see if any codes show.
One more thought,, even if all these were wrong why would it act like its in forward and reverse at the same time ? It`s a strange sensation ,,I know that sounds nutz,,
I just ut that aside until I know the others stuff is working or not,, now to fix the no start
To restart her in park or neutral you have to hold the peddle to the floor and she will start after cranking for for a while but once again runs like crap and have to keep the RPM up or will die even when not in gear.
Now,, let her sit overnight or long enough to be bone cold and she starts up and run fine until the ECM kicks in again,,
I am lost here,, not sure what to do,,
I could find another ECM and try that but at the price of one and actually finding one that seems like just throwing parts at the problem .
Best scenario would be finding one on loan but thats almost impossible.
Any thoughts ?
That's essentially when the engine coolant temperature reaches about 120 degrees, and / or in conjunction with the Oxygen sensor being warm enough to start reading exhaust temperatures... and then it switches over.
If your Corvette starts running like *** at that point, it means the ECM is getting improper signals from the sensors.
The primary sensors that can cause this are:
- MAP Sensor
- Coolant Temperature Sensor
- Throttle Position Sensor
... not in any particular order.
You also have a MAF sensor too, and an Intake Air Temperature sensor.
- MAP Sensor
Yeah , I get that, I`ll have to look at my file`s and see what I have done and replaced. this has been going on for a couple years now and I haven`t done crap for 6 months or so because I am out of patients ,, and YES,, Open loop when cold,, closed when warmed up,,
That is once I get the starter situation figured out.
Now the first thing is to find out why she won`t start, then run the checks I am getting now. I do appreciate all the feed back,\.
Maybe focus on HOW to fix the NO START problem first ,,
Is it the factory security system ,, how to check
Is it the chip in the key? How to check/ bypass, I know you can find the two wires from ign switch and put a resistor in line from what i have read
Tap into the starter wire to bypass the whole system ? any idea which wire ?
ETC
