Fuel pump
Old Feb 23, 2026 | 09:01 PM
Cor29's Avatar
Cor29
Default Fuel pump
Shopping around for a fuel pump, I came across pumps from GM and others less expensive generic ones on corvette depot.
is it worth getting the ac delco pump or will the less expensive one will do?
Old Feb 23, 2026 | 09:13 PM
WVZR-1's Avatar
WVZR-1
TI Automotive Aftermarket – Fuel Your Adrenaline
A few local uses strictly TI products for everything that they do. They've many choices. GM doesn't manufacture any longer and that other you mention buys only what's available for the least amount of $$, then sells generally for above market/
Old Feb 23, 2026 | 10:03 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm in the process of looking for a pump for my C4. I put in an ACDelco pump a couple years ago (Box said made in China ). Put about a half hour use on the pump, and then life kept me busy with non-C4 stuff the past year or so. Tried to start the car a couple weeks ago and the fuel pump was No Op. Needless to say I won't be replacing that pump with another Chinese ACDelco pump.
Old Feb 28, 2026 | 12:36 PM
merc49's Avatar
merc49
Deatsch Werks fuel pump $100 with screen, gasket, and associated parts. Eliminate the fuel pulsator too. Mine was leaking causing fluctuating pressures and making the pump work harder. Just my 2 cents.
Old Feb 28, 2026 | 02:14 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
WVZR-1's link is what you want. Ony thing is ''there's ''no information to display'' when you click them to compare the part numbers for the search results returned for your specific pump.
Made in USA...
Old Mar 3, 2026 | 09:37 PM
indjesse's Avatar
indjesse
I installed just the pump and used a
Delphi Automotive Fuel Pump - FE0114
from Oreilly's. You will need to buy the pick up sock filter and maybe the assembly flange rubber gasket if you cannot reuse the original.
Old Mar 4, 2026 | 06:28 AM
mazdaverx7's Avatar
mazdaverx7
I installed a Delphi fuel pump in my father in law's 93 last summer. It appeared to be a quality pump and has worked perfectly since. I am replacing the fuel tank in my 93 here in a couple of weeks and I was thinking of replacing the fuel pump while I was in there. I'm replacing the sending unit with an AC Delco unit and was also thinking about a new pump and what I could use other than the Delphi pump. I will also look into the pump that WVZR-1 suggested.
To Fuel pump
