Pinch Weld Jack Adapter
Old Feb 26, 2026 | 07:01 PM
SteveL54's Avatar
SteveL54
Default Pinch Weld Jack Adapter
Thinking about buying this. Fits into pinch weld and holds with magnet so you can position the floor jack.
Anyone ever used one?
DEDC Universal Aluminum Grooved Magnetic Jack Pad, Jacking Puck Pinch Weld Frame Rail Adapter, Oil Change Mush Haves,...
Old Feb 26, 2026 | 07:26 PM
bluestreak63's Avatar
bluestreak63
I bought those. And another set that advertised a shorter distance between where the pinch weld would rest and the top of the two verticals. You just need to be careful with placement, as the vertical can start bending into the fuel line or bending the fuel lines if you know what I mean.
Old Feb 26, 2026 | 07:50 PM
mrlmd's Avatar
mrlmd
I use them on my ZR-1 and any other car with pinch welds and they work great,
Old Feb 26, 2026 | 08:38 PM
SteveL54's Avatar
SteveL54
Thanks. Yeah, I know exactly what you mean.
SteveL54's Avatar
SteveL54
Originally Posted by mrlmd
I use then on my ZR-1 and any other car with pinch welds and they work great,
Thank you.
Old Feb 26, 2026 | 09:40 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
I also recently purchased these.
I used them on another car and they worked just fine. I will try them on the C4 the next time I jack it up.
Old Feb 26, 2026 | 10:30 PM
FAUEE's Avatar
FAUEE
I bought them and send them back. They didn't fit the C4 with the body panel being right there too. I got rubber ones that have some flexibility, they work much better and have some give so they can go where you want them. At the end of the day, they don't really do anything but give you a little more lift. The jack will contact the pinch weld first regardless.
Old Feb 26, 2026 | 10:49 PM
C4barnrescue's Avatar
C4barnrescue
I bought one at Harbor freight.
Old Feb 27, 2026 | 01:14 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
ive always used a tiny 3” piece of 2x4. they work perfectly because pinch weld bites into woodgrain a tad.
both on floor jack and on 2post
Old Feb 27, 2026 | 03:46 PM
mpaquette's Avatar
mpaquette
I use them on all my cars that "require" jacking at a specific point. Magnet does not always stick to pinch weld but no big deal to me.
Old Feb 28, 2026 | 10:55 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Only horror I've heard from these is "I forgot to remove it, now it's on the side of the street somewhere".
Me ol' hockey puck is still doin' jus' fine after 11 years.
To Pinch Weld Jack Adapter
