Smaller Wheels?
Old Feb 21, 2003 | 04:26 PM
Feenix566's Avatar
Feenix566
Default Smaller Wheels?
Has anyone ever tried to put wheels on a C4 that were less than 17" wide? I was thinking that might look different and cool, and maybe even transfer more power to the ground, but there's also a chance the smaller wheels wouldn't even fit over the breaks...
[Modified by Feenix566, 4:26 PM 2/21/2003]
Old Feb 21, 2003 | 04:29 PM
VetBoy89's Avatar
VetBoy89
Default Re: Smaller Wheels? (Feenix566)
Wouldn't that give you a big 'ol gap between the tire and wheel well? :crazy:
Old Feb 21, 2003 | 04:43 PM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
:confused: :confused: :confused:
Old Feb 21, 2003 | 04:45 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Smaller Wheels? (VetBoy89)
Not if you had the appropriate tire size. Rim size doesn't matter as long as the overall diameter of the tire is the same.
Old Feb 21, 2003 | 05:09 PM
Mikez40's Avatar
Mikez40
1984 TO 1988 came with 16" wheels. The side walls have a lot more rubber showing. The 17" look much better with shorter side walls. That means better cornering. You would lose some handling control with smaller wheels and widder side walls.
[Modified by Mikez40, 4:12 PM 2/21/2003]
Old Feb 21, 2003 | 11:21 PM
TurboVette's Avatar
TurboVette
I'm not sure how cool it looks but I'd like to be able to get a set of rear 15" rims to mount some et streets that match the 17" front wheels (GS or ZR1). My 15" et streets hook much better (more sidewall and 28” tall) than my 16" et streets but the 15" rims don't match and attracts officer friendly.
To Smaller Wheels?
