New Member
Old Mar 20, 2026 | 01:45 PM
tlandrum's Avatar
tlandrum
2nd Gear
Default New Member
Hey Everyone. I'm needing help to open a hood on 95 Corvette ZR1. I've tried the bar, which was ordered off the internet from a Corvette owner. Can't get it to work. I've took the wheel wells loose, my arm isn't long enough to reach the latch. I called a Chevrolet dealer....that was a laugh. They suggested taking it to a rebuilder. SMH I really need help!
Old Mar 20, 2026 | 02:43 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Moving you here to C4 General for further assistance.. good luck and Welcome
Old Mar 20, 2026 | 03:41 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Depending on which side is not releasing, I'd take the top off and parallel drive it up on a steep incline so that the side that isn't releasing is lower than the side that does and give it a good pull.
Actually probably better to parallel drive it on a steep incline both ways to see if it'll pop.
It probably will.
Probably the only saving grace of the C4 being so flexible without the top on.
Assuming it's a coupe.
That's how I got mine to release when the little clip broke on the end of the hood release cable in order to repair it.
Old Mar 20, 2026 | 03:47 PM
CorvetteRules's Avatar
CorvetteRules
I suggest after you get it open you install Ecklers Emergency Hood Release Cable Kit (84-86 Corvette C4) to save from any future problems.
Old Mar 20, 2026 | 03:59 PM
kkupec02's Avatar
kkupec02
Welcome!!
Old Mar 21, 2026 | 08:08 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome, I bought Eckler release, it didn't work?
What worked a metal coat hanger from the cleaners worked perfectly, I pulled it to make a hook, with little bend slipped into the hood seal and went fishing pulling it back and fourth till I felt hook and open that took about 15 minutes.
Good luck!
Old Mar 21, 2026 | 10:44 AM
tlandrum's Avatar
tlandrum
2nd Gear
Good luck!
I’m gonna need all the luck I can get!
To New Member
