Clear Targa top. Question
Old Apr 4, 2026 | 09:33 AM
Ed Johnson's Avatar
Ed Johnson
Default Clear Targa top. Question
Can my clear blue targa top be wet sanded and buffed with 3000 grit to remove scratches? They are very light. Has anyone done this before?
Old Apr 4, 2026 | 12:11 PM
FostersPerformance's Avatar
FostersPerformance
If they are on the outside, yes. If its crazed however nothing you can do besides replacing it.
Old Apr 5, 2026 | 06:22 AM
mazdaverx7's Avatar
mazdaverx7
The crazing is fairly normal to see on these tops. Both the blue and bronze tinted tops can craze and it can get worse if the car is stored outside year round. I found that out the hard way unfortunately. Light scratches can be taken care of as mentioned above. The crazing appear to be cracks below the surface of the top. They are cosmetic and will not be the cause a leak from the top.
Old Apr 5, 2026 | 06:18 PM
Ed Johnson's Avatar
Ed Johnson
Default Targa top
I think the car was stored inside most of its life, the top only has some light sctraches, I was hoping to try some 3000 grit and polish to remove the scratches. Do you think I should use polish made for plastic or light polish?
Old Apr 5, 2026 | 11:49 PM
Corvette_Dez's Avatar
Corvette_Dez
This is from the C6 forum but it should work just as well on a C4 top.
https://www.corvetteforum.com/forums...finishing.html
Old Apr 6, 2026 | 07:43 AM
82-T/A's Avatar
82-T/A
Yeah, the "crazing" that you see is as a result of the acrylic top basically creating lots of micro-cracks as a result of sun and the chemicals slowly leaching out of it.
I restore mechanical watches as a hobby, and many of the older ones from the 50s and such have "crystals" which is the name for the acrylic / plastic dome that covers the watch face. These do the exact same thing. Unfortunately, there is very little that you can do. One thing that people tend to do is use an acrylic polish across the top and bottom, and then use a graphine type of solution to help fill the micro-cracks as much as possible. You can then wax it and it'll look a LOT better (at least 50% reduction in visible crazing).
To Clear Targa top. Question
