Is it me
It was a different era though, they are a lot better at packaging things now, just the motors aren't as interesting looking.
The LS is not a pretty motor in any way for example, least on the outside. I've seen more and more parts to hide the coil
packs and such on them lately so I guess I'm not the only one that thinks that.
The L98 took that a step further with the beautiful flowing intake runners and the retention of the magnesium valve covers. The L98 retained some of the black and grey theme, but the engine bay was considered a work of art by many in that time period. The LT1 is a much simpler design both in servicibility and packaging. Its a beautiful engine in its own right. Its just a little more dull and refined. I find it fairly easy to work on. The LT4 added the red paint to the intake manifold and I personally think it looks great. The LT5 is a thing of beauty. Servicing it a little more of a challenge, but in my opinion, its a gorgeous looking engine. I feel as though GM did a really good job overall on each engine design of the C4.
Also... another thing that people should probably consider. Even though the Corvette is a high-value / high-priced car... and GM's flagship for technology along with top-tier Cadillacs (at the time of our C4s), they still built the engines in a different location from the rest of the car. The final "completed" engine were engineered for ease of installation into the car. So wiring harnesses and tubes and piping and everything was not designed to make it necessarily look good or be easy to work on, but instead to make it nearly fool-proof to install during time of assembly.
The engine compartment might look quite a bit differently if the engine wiring harness was installed in the car first, and THEN installed onto the engine after installation (for example). Instead, the engine wiring harness comes with the completed engine, and merely connected at the bulkhead with the chassis harness.
From an engineering standpoint, Form follows Function, and i appreciate that ideology. Until it makes things harder to work on!
LT1/ 4 /5 are clean and cool visually
Less is more 👍🏻my main bone to pick is the 'achievement'(?) of having all the accessory drives on one side of the engine 🤔 a shorter belt is about the only real benefit. Harder to access stuff, and in C4 case anyways, worse Lt/Rt weight balance 🤷♂️ same generation F-body's hang accessories on the passenger side 👍🏻 Somehow America's Sports Car got setup with NASCAR weight bias?? Driver, battery and all accessory drives on the Lt side. Battery should have been in a cubby behind the passenger seat, and the A/C compressor should be on the passenger side of the engine (like the earlier cars). Shorter hoses alone would have made it more efficient by being closer to the hvac housing at the firewall/ cabin, much less, the heat exposure from the cluster of other accessories on driver's side. The power steering reservoir could move forward, or better yet, over to the driver's side were the pump actually is. There'd be ample room with the a/c compressor not there. slightly less cooling effect with reservoir on that side now, but we already have a cooler up front. Increase it's efficiency! Sorry!! End of rant. I just don't understand these aspects when i look at my engine bay 😕 Otherwise, cool 30-40yr old engines to galk at 👍🏻🍻
Not a fan of covering everything up with pieces of plastic.
