Over heating
Old May 17, 2026 | 12:12 PM
snackstick's Avatar
snackstick
Default Over heating
I have a 1988 C4 5.7 TPI engine swap in a 89 S-10 that has a 2 row radiator with two 10'' electric fans and it seems to run hot when in traffic. I'm going to purchase a new aluminum radiator but I don't know if I should buy a 3 row or a 4 row. The 3 row is considerable cheaper but I don't want to come up short and it still runs hot. As always any advice will be very much appreciated.
Old May 17, 2026 | 12:37 PM
2011KLR's Avatar
2011KLR
How hot is is running?
Old May 17, 2026 | 01:41 PM
snackstick's Avatar
snackstick
Enough for it to puke water up. 240+.
Old May 17, 2026 | 01:45 PM
Nexxussian's Avatar
Nexxussian
This ^^^
If it's running overly warm, I remember reading things to do in the Jaguars That Run, S10 V8 swap book.
I don't recall where I have that book in storage, but the first thing I remember out of it was they listed a specific application that had the largest production radiator that could be made to fit in the S10 core support.
I would take that suggestion from the book and put the largest radiator you can physically fit.
If instead you want to try to figure out how much larger capacity radiator you want, you could loop in a spare heater core with whatever fan you can come up with, and see how much cooler that volume gets you.
I wouldn't recommend putting the auxiliary core in the cab, put it in the fenderwell, under the bed, wherever you find the room.
I generally find the time I save by just cramming the largest radiator I can physically fit is worth (to me) the cost of the greater capacity radiator.
I seem to recall they recommended a shrouded engine driven clutch fan because it moves more air than an electric fan can.
Old May 17, 2026 | 02:09 PM
snackstick's Avatar
snackstick
I would use a clutch fan but I haven't the room. I installed the electric fans on the front side of the radiator and they plush.
Old May 17, 2026 | 03:48 PM
IHBD's Avatar
IHBD
Pro Mechanic
So. I guess you have it running and starting now? There are 112 posts in those two threads. The peeps that participated would be interested in knowing what the final resolutions were.
You didn't specify, but if it stays cool when moving, but heats up when not moving, that's airflow.
(2) 10" fans is 157 in sq of surface area. I'm guessing that a stock C4 single fan is 16" diameter, so 200 sq inches of surface area are covered in a stock 84-89 C4. You have roughly 25% less fan surface area than a stock 84-89 C4.
A stock C4 radiator has about 390 in sq of surface area. I'd also guess that because your fans are pushers, they are not mounted in a shroud where the fans will flow through the entire surface of the radiator, rather than just the area of the fans. The stock C4 fan shrouds pull air through the entire surface area of the radiator. Not just the area of the fan(s) alone.
If it stays cool when moving, but not when "in traffic" you have an inadequate airflow problem at low speeds. Not a radiator problem.Think about it.
Old May 17, 2026 | 04:15 PM
IHBD's Avatar
IHBD
Pro Mechanic
Originally Posted by Nexxussian
I remember reading things to do in the Jaguars That Run, S10 V8 swap book they listed a specific application that had the largest production radiator that could be made to fit in the S10 core support.
I remember the recommendation. I still have the book and just looked to confirm my recollection. Page 10-2: "After trying four different custom-built radiators, with varying degrees of success, we found that the 1986-1989 Corvette Heavy Duty radiator (GM PN #52453612) is the best radiator for cooling the V8 S-truck."
The take-away is to use the largest cross-flow mono-tube radiator as it is possible to fit in the application. The OP asked about 3-row vs 4-row. The C4 (and S-10) radiator(s) are mono-tube. The standard cooling version is a 1" thick core. The HD versions are a 1-1/2" thick core. Both mono-tube designs. A mono-tube design has more surface area exposed to the coolant flow than the equivalent thickness core with multiple "rows".
Old May 17, 2026 | 07:02 PM
snackstick's Avatar
snackstick
I'm sorry that I didn't post the fix on Corvette forum. I had switch to Third Generation F-Body fourm and that's where I posted the fix. I will post it on this forum as well. Lets start over on the coolent problem. Instead of changing the radiator what could I do to fix the flow problem. I'm limided in space and cannot get a fan between the engine and radiator. by the way your are talking above my head with the types of radiators
To Over heating
