1993 Corvette
Old May 29, 2026 | 05:20 PM
Tom Neusiis's Avatar
Tom Neusiis
4th Gear
Default 1993 Corvette
Has anyone experienced the interior fan remaining on after the Vette has been turned off? It drained my battery.
What should I look for?
Old May 29, 2026 | 05:36 PM
WVZR-1's Avatar
WVZR-1
Old May 29, 2026 | 09:34 PM
FAUEE's Avatar
FAUEE
That's... Not good. You gonna need to start tracing wires, you've got a short somewhere more than likely.
Old May 30, 2026 | 06:45 AM
mazdaverx7's Avatar
mazdaverx7
That seems like a backfeed of voltage to the blower motor. I would pull the connector from the blower lotor and start tracing that circuit, looking for wiring that potentially has insulation that's rubbed through and may be touching, powering the blower motor with constant source voltage. You can also check the blower motor relay. Make sure its not stick and constantly energized. You can always swap it with another relay next to it and see if the problem continues. If it stops then you know the relay was stuck in its energized state and needs to be replaced. Keep us updated on what you find!
Old May 30, 2026 | 06:29 PM
BET VETTE's Avatar
BET VETTE
I’ll check the relays
To 1993 Corvette
