Problems with 92-95 Vettes
:confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
Most times you will recognize a bad Opti by bucking, sputtering and shaking. Codes should also be thrown by a bad Opti. My water pump gave no indication that it was on it's way out.
At the same time I had the Opti/water pump done, I also had the plugs and wires replaced since it's easier to do at the same time. Total cost with labor = $1,200.00. :eek:
Never take running water to an Opti equipped motor. The Opti is very sensitive to moisture, and GM strategically placed it directly beneath the water pump. :skep: :nono:
But, Dynotech has a billet aluminum replacement for the 92-94 model in Beta testing right now. I plan to buy one of them as soon as I can, and put it on to solve the problem forever. I hear that Accel is also working on a billet opti replacement, so that will be an excellent part. If you bought the part and had a good shop install it for you it would probably total $1000.
Just put aside the money for a good aftermarket replacement opti and there is no other maintenance issue with the 92-94 Lt1 cars.
That being said, the steady engineering changes from 92 to 94 might be worth considering. The 93 has 10 lb/ft more torque than the 92. The changes to the sequential injection for 94 add up to drivability improvements, especially with the automatic, tighter shift points that you can feel SOP according to the articles at the time.
But SOP implies a good seat, and the 93 is the last year for the really "fit like a glove" sport seats. My 94 seat is comfortable, but I would say that the early seats are part of the C4 jet cockpit experience.
I bought mine from a private owner who was extremely proud of how clean the oil and engine internals were. I just had top end work done and the inside of the engine at 80K miles was perfect, no wear at all. I would be very choosy about what kind of owner I bought the car from. I would go private and not a dealer. These cars are old enough now that owner care really does matter.
I have a 94 and love it, but if I had to do it again I would buy a 93 for the sport seats, or if I could afford it a 96 for the LT4 engine.
[Modified by 94lt1torchred, 3:12 PM 2/27/2003]
Greg
I've had my '93 for 3 1/2 years now (just passed 97K miles) and I've had to rebuild the starter, replace the water pump (caught it weeping just before it really blew....talk about lucky!), converted the A/C to R134, and have done a complete brake job (upgraded to GS parts/specs). I also had the ignition cylinder go bad on me...that was the one time I had to take it to a dealer for repairs. Oh yeah, recently had the Bose head unit refurbished by Dr. Don's.
For 3 1/2 years of daily driving, I'd say that all of the above is pretty much regular/expected maintenance. It has been quite reliable. :)
It was an adhesion problem likely caused by poor surface cleaning at the factory. The RTV fell off when I removed the intake.
I'm now replacing the auto trans shifter cable because it is suddenly taking alot more muscle to pull it though from park to drive to 1st. It probably failed because the car has sat unused for so long.
John
Your best bet is to buy the newest, best conditioned 'vette that meets ALL of your expectations. Save yourself the grief of catching the fever and buying one if it has a few things you don't want. There are so many out there that it's not even funny. More than enough that are perfect for what you're looking for. Don't make concessions in what you want. One will come along. :cheers:
[Modified by GDP, 9:28 PM 2/27/2003]
