Stuck Starter
Old Mar 3, 2003 | 04:02 PM
383 Stroker's Avatar
383 Stroker
Default Stuck Starter
I recently had a new hi torque starter installed and am having problems with it. Most of the time, when I turn the key to start the car, the starter keeps cranking even if I release the key from the start position. I've also noticed that the starter keeps going a couple of seconds after I've let go of the key.
Some times the car has already started and the starter still keeps cranking (luckily, the starter disengages ffrom the flywheel so you don't hear the grinding squeal). Sad thing is that even if I turn the key to the off position it still keeps cranking. I end up having to go through a sequence of turning the key back to the on and off position several times and hitting the brake to stop it. Sometimes if I rev the engine hard once it starts it helps with stopping the starter.
To make matters worse, the car has a remote starter. I don't know if this has anything to do with it. I am in the process of having the old alarm removed and getting a new one in so hopefully that will help.
:confused: :confused: :confused: :confused: :confused: :confused: :confused:
[Modified by 383 Stroker, 4:03 PM 3/3/2003]
Old Mar 3, 2003 | 07:25 PM
greg84's Avatar
greg84
Default Re: Stuck Starter (383 Stroker)
hi,check to make sure that your positive battery terminal on your starter solenid is not touching the ignition terminal on your solenid.its the small terminal near the engine block,.good luck ,greg84 :cool:
Old Mar 4, 2003 | 12:42 AM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: Stuck Starter (greg84)
I have had about three starters do this to me. Two in my 91 L98 and one in my 96 LT4. I figured out it was the exhaust heating up really high due to too much fuel. Basically the starters got heat damaged. A heat shield blanket took care of the issues.
Old Mar 4, 2003 | 10:33 AM
383 Stroker
Default Re: Stuck Starter (ConeKLR)
Thanks for the advice, guys. ConeKLR, the problem with mine is that it's brand new (or at least I was told) and there is a heat shield in place, too.
Old Mar 4, 2003 | 11:25 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Sounds like the solinoid is sticking or the return spring is week or a really wild guess that the magnetic field from the starter motor is causing the solinoid to energize slightly and that can slow the field collapese in the solinoid, But it's just a SWAG!
Old Mar 5, 2003 | 12:38 PM
TealBlueEyes's Avatar
TealBlueEyes
I just had a problem with this myself while installing a reman. job on a stock LT-1. In my case, my old starter was failing and it got stuck and wouldn't release despite trying some of the tricks you mentioned.
You might try testing the starter by itself as was suggested to me.
http://forums.corvetteforum.com/zerothread?id=496631
Since you can actually get the starter to disengage, I'd guess it might be some sort of clearance problem when it engages. Shims or something required? Also, I noticed on mine that when the drive gear pops out, it rotates as the shaft moves to facilitate connection with the flywheel. Perhaps some starters don't do this or do it in a different direction which might tend to keep them stuck on the flywheel despite the force of the return spring ?? I dunno...I'm reaching here.
Old Mar 6, 2003 | 12:45 AM
his touch's Avatar
his touch
Default Re: Stuck Starter (TealBlueEyes)
Sounds like the bindix gear is too close to the flywheel gear and it is hanging on. YOu need a shim. You can get those at any good parts house with instructions. Some applicatoins come with shims.
Let us know how it turns out.
Ron
Old Mar 6, 2003 | 11:52 AM
stillthere's Avatar
stillthere
Default Re: Stuck Starter (his touch)
sounds like a bad bendix to me. i have heard of a starter bendix being bad out of the box. take it back and try again.
To Stuck Starter
