Intake Bolt Torque Needed Please!
Old Mar 7, 2003 | 10:44 AM
KYVette90's Avatar
KYVette90
Default Intake Bolt Torque Needed Please!
I'm putting an intake back on my 98 Chevy Tahoe. I need to know what the torque is supposed to be set to and what is the bolt torque pattern. Thanks alot. :cheers:
Old Mar 7, 2003 | 10:58 AM
Ceptor's Avatar
Ceptor
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
Default Re: Intake Bolt Torque Needed Please! (KYVette90)
If nobody comes thru with a quicker answer - I can get those numbers from
my 2000 Silverado shop manuals and send it to you on Monday.
I doubt the torque settings would be different between the engines...
my book covers the 4.8, 5.3, and 6.0 liters...yours is what, the 5.7?
Old Mar 7, 2003 | 11:00 AM
scorp508's Avatar
scorp508
Torque settings will also change if you are using engine oil or thread sealer on them.
Old Mar 7, 2003 | 11:44 AM
KYVette90's Avatar
KYVette90
Default Re: Intake Bolt Torque Needed Please! (NC91L98)
It's the 5.7 350. I will be putting permatex type 2 on the intake bolts. Any help would be appreciated. Thanks. :cheers:
Old Mar 7, 2003 | 12:59 PM
Hamert's Avatar
Hamert
Lower Intake Manifold Bolt
First Pass In Sequence 3 Nm (27 inch lbs.)
Second Pass In Sequence 12 Nm (106 inch lbs.)
Final Pass In Sequence 15 Nm (11 ft. lbs.)
Upper Intake Manifold bolt
First Pass In Sequence 5 Nm (44 inch lbs.)
Final Pass In Sequence 10 Nm (88 inch lbs.)
[Modified by Hamert, 1:04 PM 3/7/2003]
Old Mar 7, 2003 | 01:02 PM
Ceptor's Avatar
Ceptor
Cruise-In V Veteran
Sure.....ya might wanna check on mychevytruck.com forum...and automotiveforums.com in the chevrolet section too. Lots of techies
answer these type questions rather quickly. :seeya
Old Mar 7, 2003 | 05:28 PM
KYVette90's Avatar
KYVette90
Hamert, AWESOME man, thanks alot! Thanks guys. :cheers:
Old Mar 7, 2003 | 06:57 PM
Hamert's Avatar
Hamert
I'm always willing to help out fellow forum members when I can. Hope the install goes well...
To Intake Bolt Torque Needed Please!
