Differences between C4 models? Please help!!!
Old Mar 13, 2003 | 02:11 AM
roadracer247's Avatar
roadracer247
Default Differences between C4 models? Please help!!!
Okay I am trying to figure out what the differences are between the years of 1990-1996. All I know is that there is a ZR1 which is much faster and I think that in '96 they offered the LT4 which is supposed to be faster then a LT1 but the ZR1 is still the fastest of the C4 models. I hope what I just said made sense. Anyway are there any differences between those years? I am asking because it seems like they are the same which makes me wonder why pay the extra money for a '96 when I could go out and get a '90 or '91 for a much better price.Please help! :)
Old Mar 13, 2003 | 02:16 AM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Differences between C4 models? Please help!!! (roadracer247)
90 or 91 will have an L98, not an LT1. The optispark was redesigned in 95 (i believe) making it more reliable. There are many other subtle refinements I'm sure as you advance up from say a 92 to 96. 94 introduced dual airbags (bye bye glove compartment). What else you looking for?
Old Mar 13, 2003 | 02:23 AM
roadracer247
Okay so I guess I want a '92 through '96. And you said something about '95 being more reliable? Could you please explain...
Old Mar 13, 2003 | 02:36 AM
vetteweiser
Cruise-In V Veteran
Vented optispark. Basically, water doesnt mess with it as bad. They are designed to keep the unit drier, hence expanding its life span.
Here's a few things from the Black Book, on 95 refinements.... improved stictching in seats, hidden velcro to reduce rattles, stronger cd player supports to prevent skipping, and a drip tube in the A pillar weatherstrip to improve water intrusion control (see, told ya there are many minor improvements :D)
Also the 95 had different front fender gills.
btw, if you havent already, pick up the Corvette Black Book. Its full of good info. :cheers:
Old Mar 13, 2003 | 03:10 AM
CanadaVette's Avatar
CanadaVette
Default Re: Differences between C4 models? Please help!!! (vetteweiser)
Where can I find this book?
Old Mar 13, 2003 | 03:20 AM
RedRiderZR1's Avatar
RedRiderZR1
Knowing you lose the glove compartment in a 94 and up, I'd go for the 92-93 LT1. :lol: :lolg:
Old Mar 13, 2003 | 03:39 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Differences between C4 models? Please help!!! (Gregs_90_ZR1)
The ZF trannys were also stronger in the early years ('89-'94...I think were the black tag trannys). The drawback to the '92-'93 LT1s are that they are speed density instead of MAF, which makes them a little more sensitive to mods, such as cams and whatnot.
Old Mar 13, 2003 | 08:33 AM
vette_dreamer's Avatar
vette_dreamer
There is a web site that tells what's new/different each year. I can't find it, but I am sure someone else will post it here.
Old Mar 13, 2003 | 09:07 AM
TimC's Avatar
TimC
CI 3-4-6-8-9 Veteran
Default Re: Differences between C4 models? Please help!!! (vette_dreamer)
Here's one site that shows some of the differences:
http://www.geocities.com/MotorCity/4310/vetfacts.htm
Old Mar 13, 2003 | 10:51 AM
vetteweiser
Cruise-In V Veteran
Default Re: Differences between C4 models? Please help!!! (CanadaVette)
Barnes & Nobel, Books-A-Million, I'm sure Amazon.com has it too.
Old Mar 13, 2003 | 02:04 PM
webs92's Avatar
webs92
Don't forget the '90 had the concave tail, and they started with the convex tail in "91. '92 was the beginning of the LT1 small block. I believe in '93, maybe '94, they started with keyless entry.
Old Mar 13, 2003 | 03:15 PM
Gary04Z06's Avatar
Gary04Z06
This is about the most comprehensive info you can find: http://corvetteactioncenter.com/specs/index.html
For example, here is a suspension comparison chart: http://corvetteactioncenter.com/tech/c4/susp_chart.html
Just pick your catagory and learn..... :thumbs:
[Modified by Gary96LT4, 2:18 PM 3/13/2003]
To Differences between C4 models? Please help!!!
