c4 front suspension...
Old Mar 13, 2003 | 03:25 PM
84TAVeRT's Avatar
84TAVeRT
Default c4 front suspension...
anyone with pics of a c4 front suspension out of the car...
does the k-member unbolt with the complete front suspension in tact like on the c5...
i am guaging how difficult it will be to modify my truck to take a c4 front suspension...
thanks,
Chris
Old Mar 13, 2003 | 03:48 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: c4 front suspension... (84TAVeRT)
I don't have pic's yet, but to answer your ? the cross-member does unbolt from the frame but not untill the a-frames (all 4) are removed and the streering column is detached. I'm doing this to my '84 on friday/saturday, so I may be able to post some pic's after we're done ! ! ! !
:party:
Old Mar 13, 2003 | 04:27 PM
84TAVeRT's Avatar
84TAVeRT
what i really need to know is if the suspension will support the crossmember and engine once it is unbolted from the frame...
if so, it will be fairly easy to graft the c4 front k-member and suspension into my truck chasis...
eventually i hope to be able to have my 68 datsun truck rolling on c4 suspension with a 350 and manual trany...
thanks,
Chris
Old Mar 13, 2003 | 08:13 PM
ZR1991's Avatar
ZR1991
Happen to have these on my site.
Don't know if they help, but they are purty.
Old Mar 13, 2003 | 08:17 PM
ZR1991's Avatar
ZR1991
Default Re: c4 front suspension... (ZR1991)
I just saw your second question.
I have an Everette Morrison Cobra Replica build manual, and it has detailed instructions for installing the C4 front into a Cobra (basically a standard car type frame).
If I can dig it out tonight, I will scan and post it, if you would like.
As I recall, it was very helpful, gave it to someone else once.
Old Mar 14, 2003 | 07:37 AM
edsalinas's Avatar
edsalinas
Your pic's didn't come across ? ? ? Would love to see 'em.
:lurk:
Old Mar 14, 2003 | 07:41 AM
edsalinas's Avatar
edsalinas
thanks,
Chris
It would be very cumbersome to deal with that way? The steering linkage and sway bar need to come off. The spindles/a-arms & shocks stradle the frame rails so that would prevent the removal of the x-member. . . . . . . .
Old Mar 14, 2003 | 12:46 PM
84TAVeRT's Avatar
84TAVeRT
Default Re: c4 front suspension... (edsalinas)
ok... so does the frame tuck in between the upper and lower control arms and the k-member?
i also assume that the k member is lifted out of the frame and not dropped down like on other cars...
To c4 front suspension...
