I got a wild idea and reconnected the CAGS on my 96. Previous owner had unplugged it and added the proper add-on. The weird thing is that the tranny seems to shift smoother than before (in all gears). Does this seems right to ya'll, or am I just see/feeling things?
Also, I don't recommend backing up the rear tires on rhino ramp. It aint as easy as it seems and it aint pretty if you screw up. :nonod:
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Reconnected CAGS (96GhostLT4)
I had my CAGS disconnect some time ago, but didn't use the Eliminator. I just now finished installing an Eliminator and will let you know shortly if there is a difference in feel. It didn't make any difference before....
I just had it programmed out when I had the custom chip burnt. Like stated before, it's really no problem if you drive em like they should be driven. 84 CF 91 ZR-1
