Scratch in Top HELP!!!
Old Mar 16, 2003 | 08:22 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Default Scratch in Top HELP!!!
Can the acrylic top be polished? I made a pretty deep cut about 8 inches long along the passenger side trim. Can it be sanded and polished? :sad:
Old Mar 16, 2003 | 08:29 PM
ncsugreywolf's Avatar
ncsugreywolf
Default Re: Scratch in Top HELP!!! (LowFlight)
Good question and I have no idea. I would like to know also!
JJL :lurk:
Old Mar 16, 2003 | 08:42 PM
jefft84's Avatar
jefft84
plastic polish takes out light scratches , 3M makes a pretty good product. If it is deeper than that will take out you can use a 1000 grit sand paper then polish.
Old Mar 16, 2003 | 08:50 PM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Default Re: Scratch in Top HELP!!! (jefft84)
So I just wet sand it with 1000 grit sandpaper and then polish it with the 3m stuff? Do you know the exact name of the 3M polish?
Old Mar 16, 2003 | 10:03 PM
vanduker's Avatar
vanduker
I think there is a bit more involved than the sanding and polishing. There is a coating on the top - the coating is what "scales" off after a few years.
I'm not sure how the top will blend between the scratch area (where you will sand through the coating) and the area where the coating is still there. It may look great but it might not.
I removed the coating from mine because it was scaling. I used 600, 1200 and then 1500 grit wetsanding paper and then polished with a buffer (non orbital) and glaze polish. Be careful not to buff to hard/long on any area as the top will melt.
Not trying to scare you off, and my top looked fine, but I wonder how it will blend between the coating.
Mark
Old Mar 16, 2003 | 10:11 PM
vette_dreamer's Avatar
vette_dreamer
unless you know exactly what you are doing, I wouldn't try sanding it.
Old Mar 16, 2003 | 11:19 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Scratch in Top HELP!!! (vette_dreamer)
With a little patience it's no big deal. I did all hand sanding then used a buffer with polishing compound at the end.
http://www.corvetteforum.net/c4/blue92/targa_top.shtml
Old Mar 16, 2003 | 11:32 PM
baddmann's Avatar
baddmann
Default Re: Scratch in Top HELP!!! (Blue 92)
Blue92, that looks great!
LowFlight, I say go for it and just take your time...
Old Mar 17, 2003 | 01:14 AM
ncsugreywolf
Thanks Blue..great to know info!
:thumbs:
JJL
Old Mar 17, 2003 | 07:36 AM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Thanks Guys... :cheers:
Old Mar 17, 2003 | 07:42 AM
Bear86's Avatar
Bear86
A good body shop can sand and polish it. :cool: :cool: :cool:
To Scratch in Top HELP!!!
