Water leaks
Old Mar 21, 2003 | 10:35 PM
corvette8585's Avatar
corvette8585
Default Water leaks
Every time it rains I get water in from the front corners of the windows. It usually runs along the edge of the dash and pours in all over. I hear this is rather common among the c4 and even saw a book for $20 on how to fix this. Any suggestions on how to stop the flood? These leaks occur with only a light rain.
[Modified by corvette8585, 4:27 AM 3/22/2003]
Old Mar 21, 2003 | 11:08 PM
J Z06's Avatar
J Z06
Default Water leaks
It really has to rain HARD for mine to leak(or going to a high pressure car wash). It's common on windows that don't have frames around them to leak just a little.
Maybe you can adjust the windows to go up a little tighter to see if that helps.
Good luck.
Old Mar 22, 2003 | 01:02 AM
linkschamp's Avatar
linkschamp
Default Re: Water leaks (corvette8585)
According to the 1993 CCT (Certified Corvette Technician) Corvette Waterleak Diagnosis & Repair Manual, GM recognizes five (5) major types of waterleaks. They are: 1) top panel to retainer, 2) glass to weatherstrip, 3) weatherstrip to weatherstrip joints, 4) top panel to weatherstrip & 5) retainer to body.
To identify which leak you may have, the manual advises someone sits inside the vehicle with a flashlight while another person runs water from a simple garden hose over the locations listed above. They advise using only a small stream of water - not to create a flood! :nonod:
If you could identify which location is your problem, I could possibly send you information regarding repair (if your leak is the glass to weatherstrip area - you are NOT going to like the extensive repair steps!).
Good Luck! :seeya
[Modified by linkschamp, 6:04 AM 3/22/2003]
[Modified by linkschamp, 6:05 AM 3/22/2003]
Old Mar 22, 2003 | 02:52 AM
CanadaVette's Avatar
CanadaVette
In my old C-3 I had to wear rubber boots when driving in the rain.
Old Mar 22, 2003 | 08:01 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Water leaks (JD 90 383)
:iagree: ...ASSUMING the weather stripping's in decent shape...that should help...but it won't totally stop it. I just carry a terry wash cloth under the seat and "wedge" it up to absorb the water in heavy rain.
Old Mar 22, 2003 | 10:09 AM
92PoloVette's Avatar
92PoloVette
CI 6-7-8-9 Veteran
Default Re: Water leaks (Alchemist)
:withstupid: :yesnod: :yesnod:
Old Mar 22, 2003 | 11:36 AM
rideklein's Avatar
rideklein
Don't bother with the book... I bought it expecting help on the same leak area as you. It gives "general" water leak and wind noise solutions along with specific solutions for some C3 problem areas.
High probability just replacing the weatherstrip won't solve your problem (it didn't for me). The trick is to take off the roof front w/s and then take off the w/s rails (one on each side of the windshield and one on the top) and reseal them. This is where the water leaks -- believe it or not. After you've done this you may have to adjust the door glass for best results.
If you have any other specific ?'s, ask 'em here or shoot me an email...
rideklein@mail.com
Old Mar 8, 2014 | 03:35 PM
StPeteC-6's Avatar
StPeteC-6
Navigator
One other item you might want to check is your door hinge. Open door, reach down and
see if you can wiggle the door on it's hinges. If so, your door(s) are drooping when you
open them and when you close you door, the window is not meeting the weatherstrip
properly and the resulting gap is the source of your water intrusion.
Check it. I just finished rebuilding one of my hinges with this same water leak issue.
Mid America Mtrs has a Door Hinge Pin & Bushing Rebuild Kit for about $20 that
solves this problem.
Good Luck.
Old Mar 8, 2014 | 05:44 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
evidently the op has moved on and has corrected his problem as this thread is 11 years old.
Old Mar 8, 2014 | 06:58 PM
StPeteC-6's Avatar
StPeteC-6
Navigator
Duh.... missed the stale date completely with my input. Well, perhaps another
owner can benefit from the suggestion........
Old Mar 9, 2014 | 01:16 AM
94flavette's Avatar
94flavette
Not only that, but if you look at the OP's profile, it's a month shy of 10 years since he last logged into the forum.
Old Mar 10, 2014 | 12:20 AM
RpgMakerJohn's Avatar
RpgMakerJohn
Hilariously, this is information I was about to post about So now I know!
Old Mar 10, 2014 | 08:52 AM
StPeteC-6's Avatar
StPeteC-6
Navigator
Glad I injected a suggestion that I had not seen on any of the other
forum water leak threads about door hinge(s) being the culprit. Hope others benefit even if it was a 10 year old thread.
To Water leaks
